Which wire is signal coming out of the T56 VSS??
Old 07-09-2002, 04:29 PM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
Here's my problem. The T56 I bought had no wiring harnesses with it so I had to buy the GM pig tails for the sensors. The harness that plugs into the VSS has two identical white wires, so I don't know which one is the signal wire. Is the one near the front or back of the car the signal wire. Any help would be great.
Old 07-10-2002, 11:44 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Both. Or neither. Take your pick.
The real answer is it doesn't matter. Connect one line to ground, then the other end is signal. I doubt I could even tell you which side I made ground without tracing the wires back.
Old 07-10-2002, 02:27 PM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
Thanks, I just talked to Dakota Digital and they said it's an AC output. So it doesn't matter what is ground or signal.
Later
Caspar
06-19-2016 11:19 PM
BlackphantomZ28
LSX and LTX Parts
10-19-2015 06:25 PM
BlackphantomZ28
08-31-2015 10:29 AM
jharrison5
08-19-2015 05:53 PM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: Which wire is signal coming out of the T56 VSS??
