Tranny temp monifold, return or sender line?
Old Jul 9, 2002 | 08:07 PM
flotsamm's Avatar
I just installed a freshly rebuilt 700r4 and bought a Autometer temp manifold(t-fitting with sensor provision) so I can read my tranny temps. When installing it, I decided that I would put the mainfold on the sender line since I wanted see what the trannys temp was before getting cooled. Now I thinking after reading various posts that most people read the temp from the return line side.
Does it make more sense to know the temp before it gets cooled or after? Thank you.
Old Jul 9, 2002 | 08:26 PM
scauffiel's Avatar
I added a bung directly to my deep tranny pan - I wanted to know what temp the tranny was sucking up.
S.
Old Jul 10, 2002 | 08:14 AM
flotsamm's Avatar
Thanks for the reply. I understand that the best way is to monitor the temp from the pan, but I chose not to do it this way due to time limitations. Maybe next time I change my fluid I'll put the sender in the pan.
But for now, does anyone have a preference on which line they would use? Sender or return?
Any help is appreciated, thank you.
Old Jul 10, 2002 | 06:02 PM
86_Dan_Z28's Avatar
Car: 86 Z28
sender
Old Jul 10, 2002 | 06:47 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I put my sender in the pan as well.
mike_c
Aug 27, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
NBrehm
Aug 25, 2015 11:49 PM
spaigo
Aug 21, 2015 07:46 PM
