what else holds these stupid pedals in?????
Old Jul 11, 2002 | 12:23 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
i got the two braces that bolt to the clutch master cylinder cylinder, what else do i need to remove, i would prefer to not take out the steering column if at all possible, i have already removed the 2 nuts allowing it to drop down a bit, also what are the odds that my automatic car is gonna have all the wiring for the clutch switch?
Old Jul 11, 2002 | 12:50 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Well...i just did an automatic to stick swap on my 83 TA. Was very easy. Started on Saturday night at 7:00pm and worked on it to around 11:15pm, and Sunday morning 11:00am to around 1:00pm. VERY EASY. But onto the pedals....there are 4 studs that come through the firewall from the brake booster, the 2 braces as you mentioned before, and 1 bolt that goes straight up into the body that is loated almost directly above the steering column. I just took the 2 nuts off that allow the steering column to drop and got my hand pretty much right up in there. But thats all that holds the pedals in. Good luck.
Old Jul 11, 2002 | 07:10 AM
ede's Avatar
ede
how stupid could they be, they have you out smarted
Old Jul 11, 2002 | 08:28 AM
Car: 1984 Firebird
Axle/Gears: 4.10
funny ede, very funny,
t-topgta,
thanks for the info i wasn't sure if i needed to remove all 4 nuts on the booster or not
Old Jul 11, 2002 | 10:29 AM
Car: 1984 Firebird
Axle/Gears: 4.10
i got'em out now it only took about 15-20 minutes to finish the job
, it probably didn't help last night when i was trying to do it in a poorly lit garage at 12:30 am, after haveing been up for 20 hours
mattcanty
Oct 12, 2015 11:08 AM
racereese
Oct 3, 2015 03:46 PM
djmarch
Oct 2, 2015 10:41 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ironbmt
Sep 27, 2015 06:00 AM
