speedo gears affecting lockup in OD?
Old Jul 16, 2002 | 11:29 AM
Recluse's Avatar
I had my rearend gears changed to 3:73s but I have not changed the 2 speedo gears in the trans yet. While Im driving in OD with the lockup engaged A.) the lockup appears to occur really early...sometimes as low as 35 or 40 mph and B.) the converter does not want to unlock during acceleration in OD and will only unlock when the trans downshifts into 3rd -or so it seems. could all of this be related to having the wrong gears in the trans telling the car it is going faster than it really is?
Old Jul 16, 2002 | 11:39 AM
Recluse's Avatar
also, during acceleration in OD, I can tap the brake to unlock the converter but it will re-lock almost immediately after no matter how hard Im on the gas. Seems like it wants to stay locked in OD. Im sure that romping on the gas in OD with a TC that wont unlock isnt good for the transmission either.
Old Jul 16, 2002 | 03:01 PM
Recluse's Avatar
anyone?
Old Jul 16, 2002 | 04:19 PM
flotsamm's Avatar
This may not be the answer, but perhaps try checking the TV cable adjustment. It you give it more line pressure the kickdown will be more responsive and hopefully drop you back down to 3rd.
Old Jul 16, 2002 | 04:56 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Your VSS controls your torque convertor locking function. Your VSS is reading a higher mph than you are really running, and your ecm is locking up your torque converter when it thinks you are going the right speed, when, in actuality, you are going like 20 mph. Change your speedo gears
Old Jul 16, 2002 | 05:11 PM
Recluse's Avatar
Thanks, thats what I was hoping to hear.
GTAman
Jul 3, 2024 07:29 PM
64goatman
Sep 9, 2015 01:09 PM
SG91camaro
Sep 5, 2015 10:27 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
