how hard is it to...
Old Jul 16, 2002 | 01:52 PM
TunedPortZ's Avatar
how hard is it to change the gear carrier from an open diff. to a lsd type posi. a friend of mine has a 3.23 and up posi he will sell me for $70 and im sure it in good condition, i just want to know what is involved in the process. thanks
Old Jul 16, 2002 | 07:05 PM
ede's Avatar
ede
swap your ring gear to the new carrier, check back lash, refill with oil and you're on your way.
Old Jul 16, 2002 | 08:42 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
There' a little more to it than that if you want it to survive awhile. As far as changing things over it's straight foward if you have wrenching skills, just remember the ring gear bolts are reverse threads. You'll also need to check the gear mess to see if they're meshing correctly otherwise you'll take the chance of breaking teeth off and then your done.
Old Jul 16, 2002 | 09:06 PM
TunedPortZ's Avatar
thanks one more question, is a standard 10 bolt lsd, gonna spin both tires of the line? more importantly, is it gonna be a lot better than an open diff. thanks
Old Jul 17, 2002 | 06:36 AM
IHI's Avatar
IHI
As long as the clutch pack is in good shape it will spin both tires in your burnout, then throw ya back into the seat when you launch-at the track that is. On the street you'll just start hanging the rear end out when you mash it. Keep this in mind though, the rearend will "unlock" when making a turn and takes a little bit to lock up again. At our track here the burnout box is an immediate right hand turn out of stageing lane, so I have to get lined up, back straight up about 8 feet or so, then pull back into the burnout box, otherwise my posi unlocked and I just spin the one tire.
RedLeader289
May 28, 2019 01:47 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
