camaro vs vette tranny
Old Jul 19, 2002 | 10:45 AM
stock sux's Avatar
i have a 27 spline 700r4, will a 27 spline vette tranny fit. iwondering if it is the same length. and does it have the same horse power rating as the camaros or is it higher. i know the servo is different but is that it.
Old Jul 19, 2002 | 11:27 AM
ede's Avatar
ede
yep it'll fit and work, long as both have the v8 bolt pattern
Old Jul 19, 2002 | 12:03 PM
nsimmons's Avatar
if its from an 82 it will fit, if its from an early 84 you'll have to change the tail shaft. If its from any other vette late 84->mid 93 its a 30 spline
Old Jul 19, 2002 | 12:16 PM
Pro Built Automatics's Avatar
Check the length, since most Corvettes are shorter.
Old Jul 21, 2002 | 03:48 PM
stock sux's Avatar
with changing the tail shaft is that just the cover. what about the spline that goes to the drive shaft, does that have to be changed with the tail.
Azrael91966669
25
Jun 20, 2017 04:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
