t56 swap
Old Jul 20, 2002 | 08:11 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
t56 swap
i can get a t56 from a 96 lt1 trans am. it will come with the bellhousing, pedals, yoke, crossmember, master and slave cylinders. and of course the trans itself. what of these parts will work in my iroc and what would i need to still buy?
also if this is from a 96 is it for sure going to have the .50 6th gear?
thanks for all the help!
Matt
Old Jul 20, 2002 | 08:41 PM
kevinc's Avatar
Car: 1982 Z28
The stuff you listed will work except for the crossmember, but what flywheel and clutch/pp you need depends on what year your IROC is.
If it's an '85 you have a 2-piece rear main seal engine, need an aftermarket (Centerforce?) flywheel and clutch. If it's an '86 or up you have a 1-piece rear main seal and OEM flywheel/clutch will bolt up.
If it's a '94 or up trans it has the 0.50:1 OD.
Read the tech article for more info.
Old Jul 20, 2002 | 08:46 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
thanks alot kevin!
i appreciate your help, my car is an 89 so it looks hopeful.
thanks again.
matt
Old Jul 23, 2002 | 01:05 AM
83Daytona's Avatar
Where would the tech article(s) be.
Old Jul 23, 2002 | 07:47 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
the tech article is in the techical articles section of this site. just click back to thirdgen.org and you'll see it on your left.
Old Jul 23, 2002 | 07:51 PM
83Daytona's Avatar
Ah ha! I was wandering around the board home page not thirdgen.org...
Thanks for the info!
Old Jul 26, 2002 | 06:38 PM
PeteZ28's Avatar
Car: 84Z28, 98Z28
Engine: roller 350, cc Qjet
Transmission: WCT5
On the subject of flywheels
Kevin when 5 speeds are swapped into 350 cars with 1 piece main seal, is the 305 flywheel used? i.e. are the 305's and 350's balanced with the same flexplates/flywheels. I recently learned these engines are externally balanced with counterweights on the flexplate/flywheel. So potentially they could be different but from what I've seen it looks like they use the same pieces.
I'm thinking about going with a 383 and using the scat crank thats balanced to use the 350 counterweighted flexplate and was planning on using the 305 flywheel. Obviously this will only work if 305's and 350's are balanced the same.
If I went 6-speed would this same flywheel still work. Do LT1's use the same flywheel/flexplate as LB9's and L98's?
Thanks again
Pete
Old Jul 27, 2002 | 10:45 AM
kevinc's Avatar
Car: 1982 Z28
Can't help on T5 swaps, never done one. I can say for sure that T56's require a T56 flywheel and the T5 piece won't work. Clutch diameter is not equal between the two.
Old Jul 27, 2002 | 12:38 PM
PeteZ28's Avatar
Car: 84Z28, 98Z28
Transmission: WCT5
Thanks for the info Kevin.
Old Aug 7, 2002 | 10:16 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Heres a crossmember that will fit the T-56 in a third gen.
http://www.fasttoys.net/8292fbodytrans.html
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
