1-2 shift and shift kits
Old Jul 23, 2002 | 09:09 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I know that shift kits have been talked about alot but I need to know if one will help my problem. Anytime I am at WOT, the car takes forever to shift into 2nd gear. Sometime it gets to about 6000RPM. I have adjusted the TV cable but it really hasn't made much difference. I was wondering if a shift kit or the Corvette Servo kit would help. Is the Servo kit part of the shift kit or seperate? Is Transgo much better than the B&M? BTW, this is a 700R4.
Old Jul 24, 2002 | 09:17 AM
MdFormula350's Avatar
It almost sounds like it is slipping?
slipping is not good, if you are slipping i dont think any of those things will fix that.
You need to have a healthy tranny to put a shift kit, servo and all that good stuff in it.
I would also just run a search about your problem, u might find something more detailed.
Old Jul 24, 2002 | 01:17 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
That all depends. If you can hold it till 6k and the car actually pulls WOT whats the problem? If it wouldent shift a light throttle till 6K then I would see how slipping or somthing internal could be messed up.
Old Jul 24, 2002 | 07:38 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
There is no power over 5500 RPMs.
Old Jul 24, 2002 | 08:55 PM
Momar's Avatar
I would try adjusting your tv cable again and if that doesnt work it could be a stuck tv valve. If that is the case I think the transgo kit is supposed to help fix that but someone else may have a better explination
Ben
Old Jul 25, 2002 | 08:32 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Thanks, I talked to Pro-Built yesterday and he recommended the Transgo Reprogramming kit. What is the difference in the reprogramming kit and the shift kit? I have seen two different Transgo kits.
Old Jul 26, 2002 | 07:47 AM
http://www.txchange.com/transgo.htm
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
