what tranny would you get
Old Jul 23, 2002 | 03:10 PM
man_of_steel27's Avatar
Car: 92 RS - For sale
Transmission: 700 R4
Axle/Gears: yup, it has a peg leg
ok i have posted this before should I replace my stock 700R4 tranny with a turbo 350 or should should I get another tranny or get my 700R4 rebuilt if not to hard I will do it my self with help of others, please help by the way I will be getting a 350 in my car too.
a friend said the 700R4 is better cause it is a four speed rather that the two speed turbo 350, true yes or no
Old Jul 23, 2002 | 03:24 PM
ede's Avatar
ede
your friend lied to you right off the bat, a th350 is a 3 speed, a glide is a 2 speed. the 700r4 is among the hardest trans to rebuild and have a bad history of breaking. they do have OD which a lot of people like and you can run numerically higher gears and less RPM than a th350. a th350 would require an aftermarket torque arm or a b&m adapter kit.
Old Jul 23, 2002 | 03:39 PM
so what do you think will be cheaper, what would you prefer getting it (700r4) rebuilt or buying the th350, or is there another tranny i should get
Old Jul 23, 2002 | 07:51 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
It all depends what you're using the car for. If you are using it as a weekend only car, than I would go with the TH-350. If its an everyday driver, i would defintely get the TH700-R4
Old Jul 24, 2002 | 03:45 PM
yeah it will be an everyday car and prob some street racing
derfrank why is that, i know very little bout transmissions
Old Jul 24, 2002 | 04:12 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
A 700-R4 has the .70 4th gear. That will reduce your RPM's on highway crusing about 30% from 3rd gear. A TH-350 will be like riding around on the highway in 3rd gear of your 700-R4. #rd gear on a 700-R4 is 1:1 and so is the TH-350.
Old Jul 24, 2002 | 04:18 PM
ok, understanding a little more, i think
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
