Electronic Speedo to Manual??
Old Jul 30, 2002 | 10:02 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Ok - i've got a 1988 car that i'm putting a 1989 t-5 tranny in - the problem is that the tranny is set up for an electronic speedometer and the car has the cable and such. Is there a way to convert the transmission? (I pulled the electronic assy. out and i imagine it must be possible to just plug a mechanical one in...)
TP
Old Jul 31, 2002 | 02:57 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Just plug a mechanical one in. If you have the right tooth count on the output shaft drive gear, then you're in like Flynn. If you have the wrong gear on the output, pull the tailhousing & put the right one on. I am doing this right now with my car; not sure what drive gear is in there, but I'm putting the right one in.
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
anesthes
Sep 30, 2015 07:48 AM
