Installing tranny this weekend...?
Old Aug 2, 2002 | 12:59 PM
johndo1707's Avatar
hi, i'm goign to be removing my tranny this weekend and having it rebuilt and i'll be installing it back in this weekend hopefully....i was wondering if you guys had at tips or tricks for removing it? is there anythign hidden on it that will need some extra knowledge about or anythign? any tips or stuff would be appreciated, thanks!
jeff
Old Aug 2, 2002 | 03:38 PM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
https://www.thirdgen.org/techbb2/sho...hreadid=123244
I posted a few things I remembered from my tranny swaps, I hope it helps some. If you run into trouble just let me know, chances are I ran into the same problem.
Old Aug 3, 2002 | 06:17 AM
madmanups's Avatar
I suggest a jack, swivel ratchet adapter, and lots of patience.
Old Aug 4, 2002 | 12:33 AM
EvilCartman's Avatar
Car: '82 Z28
3 foot extention for your ratchet and maybe a wobbler socket or just a regular universal attachment
Old Aug 5, 2002 | 12:18 AM
Crazy2.8V6Man's Avatar
how long did it take u to remove the old tranney and put it back in do u think it could be done in a day if i start at like 12:00.
Old Aug 5, 2002 | 03:33 AM
madmanups's Avatar
Yes, its not too hard to figure out, but it is a little tricky to and tight
Old Aug 5, 2002 | 12:21 PM
johndo1707's Avatar
hey, thanks alot guys, doesnt sound like too hard of a job....hopefully it all goes well
Old Aug 5, 2002 | 02:39 PM
Dragroc's Avatar
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
I pulled my trans twice in 2 weeks about 2 weeks ago. My best advice is to have a swivel socket, about 3 feet in extensions, and air tools help out alot. It is also best to tighten/loosen the trans cooler lines with the trans tilted down. Also try to put the dipstick on BEFORE you put it back on the motor.
Old Aug 5, 2002 | 02:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Use a real short 9/16" box wrench for the 2 top ones; it's about a hundred times easier than trying to get at them with the extensions and wobble joint.
Old Aug 5, 2002 | 03:14 PM
FJK's Avatar
FJK
Just removed 700r4 trans from an 88 gta this week end, so this is fresh in my mind. You will need a floor jack for sure. I had both a trans jack & floor jack available, but I just used the floor jack. The floor jack goes under the trans oil pan, using a piece of wood between the jack & the pan. Most items are more easily disconnected after you remove the trans mount & let the trans tilt down. Those items are the trans cooler lines, dip stick bracket, & all upper trans to engine bolts. The upper trans to engine bolts are best accessed by using a really long extension & coming in from behind the trans. Before dropping the trans mount, the torque arm needs to be disconnected. This can be done at the trans only, but you need to open the mount to remove the rubber inslulator, not remove the mount. When you remove the torque arm bushing, the torque arm will be only under a little tension providing the rear of the car is up on jack stands, but the rear axle is hanging free. Once the trans is disconnected from the engine, lower the floor jack & remove the torque connvertor. Two guys can then lift the trans off the floor jack, & slide the trans out from under the car.
camaro11j
Sep 19, 2018 08:49 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
spaigo
Aug 21, 2015 07:46 PM
crazynights
Aug 21, 2015 06:53 AM
drathaar907
Aug 6, 2015 04:20 PM
