how long will a 9 bolt hold up behind a t56
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I have a 9 bolt with precision 373s . They were set up professionally and don't wine. I will be swapping my a4 for a t56 over the winter. My lt1 is making over 400hp. I will either be running drag radials or et streets at the track. Will this rear hold up or should my plans include a 9 inch?
Oh yeah I'm looking for mid to low 12s with a 60 foot of between 1.7 and 1.9.
Kory
Kory
Car: 1984 Z28
Engine: 350ci
Axle/Gears: 3.73 12 bolt
It depends how nice you are to it.
If you launch at a reasonable RPM with street tires, it should last you a while. However, if you live at the strip, use DRs, and 5 grand it before dumping the clutch, it will likely break fairly quickly. Since your plans include DRs or et streets, it would be wise to figure on a new rear for it in the future.
DG
If you launch at a reasonable RPM with street tires, it should last you a while. However, if you live at the strip, use DRs, and 5 grand it before dumping the clutch, it will likely break fairly quickly. Since your plans include DRs or et streets, it would be wise to figure on a new rear for it in the future.DG
Car: 88 Iroc
Transmission: t 56
Thats pretty much what I figured.
I will have to run either et streets or drag radials. I can get absolutely no traction with street tires.
Kory
Kory
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
