please help me with info on rear
Old Aug 5, 2002 | 06:29 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
can someone please tell me step by step how to uninstall a rear and reinstall a another one in my camaro?
any help is appreciated
Berlyn
Old Aug 5, 2002 | 07:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Disconnect park brake cables, brake line, drive shaft, torque arm, lower control arms, panhard bar and lower shock bolts. Pull the diff out. The springs will fall out once the shocks are disconnected.
Install new diff and reconnect everything back up.
If you need a more information on how to remove or install any of that I suggest picking up a repair manual.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
