Lockup: do I need it?
Old Aug 8, 2002 | 04:45 PM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
I do not have the connection hooked up for the lockup. There is nothing plugged in there. Do I need lockup?
Should I add a lockup controller or am I fine with out it. The tranny guy that is rebuilding my tranny says I should have it otherwise the convertor will heat up and burn out. Is this true?
Also what is the cheapest lockup switch I can buy? Where?
Old Aug 8, 2002 | 05:22 PM
NCZ28's Avatar
I have also heard that the tranny will get too hot without the lockup, so I would say try to get a switch. Mine quit working, so I just wired up a toggle switch to lock it, until I can figure out how to fix it.
Old Aug 8, 2002 | 05:50 PM
transfixleo's Avatar
With 3.73's you may get away with it. I would recommend using it though. I would also recommend that you make sure that the TV geometry is correct with your carb or that will kill it too.
Old Aug 9, 2002 | 10:47 AM
jonarotz's Avatar
Car: 91 Z28
TCC
Without the TCC lock-up you will generate more heat due to the slippage through the torque convertor. If you do not want to get it working I would at least add on an auxillary trans cooler(in line with the factory one
F-body driver
Dec 10, 2014 06:37 AM
xpndbl3
Feb 7, 2009 06:28 PM
1QWIKZ
Dec 19, 2007 05:55 PM
91FF
Oct 14, 2007 07:37 PM
oxiderush
Feb 22, 2006 11:49 AM
