OK Axle decoders, I've got one for you.
Car: '94 Corvette
1982 Pontiac Trans Am
Originaly equiped with 305 CFI & TH-200C.
10 Bolts on the cover, with the code (3JX C172 2) on the axle.
I know the 'C172 2' is production date & time.
I found '2JX' or 'JX' being a 2.93 posi, but nothing showing '3JX'...
Thanks,
Ron
Thanks,
Ron
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
if you take that number to the parts department at the local GM dealer, they will be able to tell you what it was originally.
but someone is bound to chime in and say "if you haven't changed the fluid lately then it needs to be done, so pull the cover off and start counting teeth, its the only way to be 100% sure"
and EDE will be right when he says this, but i beat him to it this time
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Is there a metal plug in the rear cover? What does the RPO list say it's supposed to have?
Car: '94 Corvette
Theres no plug, but theres a tag off one of the bolts saying something about use limited diff oil or something. It's hard reading the tag, since it's on backwards.
I don't have the RPO list since the car has been striped down.
I looked through a bunch of part but couldn't find any list.
Ron
Ron
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Ron,
Did you ever find out about that code? I have one very similiar
3jh c189 2 and can't find anything on it. I do plan on taking the rear cover off to verify my gears.
Car: '94 Corvette
This maybe a month to late, but It did turn out to be a 2.93 Posi. I don't know what maker, but it had a cone type posi, so that might have something to do with the number 3 ???
Sorry 'crazynights' about the extended delay.
Ron
Ron
gixxer92
May 18, 2017 11:20 AM
