Rear Diff Question...
Old Aug 9, 2002 | 07:11 AM
IROCKER's Avatar
How do you know if your rear diff is going south? What kinda symptoms would I experience?
Old Aug 9, 2002 | 08:17 AM
MdFormula350's Avatar
certain noises, like chattering..
if you have posi, and when you burn out you should leave two of the same tires marks.. if not posi most likely is gone..
if you think you are having rear end problems i would give changing the rear end fluid, and add the correct posi additive..
sometimes people think their rear end is going bad, but they change their fluid and the noises go away and the rear end preforms like it should..
Old Aug 9, 2002 | 08:51 AM
IROCKER's Avatar
Thanks...I've got a very small leak and I was going to replace the gasket anyway, so it will be getting the fluid change then.
Now the big question...I've got synthetic in there now...do I go with synthetic again, or go back to dino oil?
Old Aug 9, 2002 | 10:25 AM
i think u should stay with syn, i just use regular stuff..
draco
Oct 4, 2015 09:25 PM
LittleFranks
Sep 17, 2015 12:22 PM
E Rod
Aug 28, 2015 05:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
happyhapka
Aug 15, 2015 04:42 PM
