Dana 36 to a 44
Old Aug 13, 2002 | 12:06 PM
fastvetteTPI84's Avatar
Dana 36 to a 44
does anyone know what would be involved with a dana 36 to a dana 44 swap my corvette ...a friend has a wrecked 90 with a dana 44 and i can have what i need to get it to fit but he wants my 36 in return so what extra parts if any will i need and how hard of a job is it ( back yard or no it needs a lift )
any help or ideas would be usefull
thanks
Old Aug 13, 2002 | 01:32 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'd ask this on the corvette forum instead of here. I know that it's a pretty popular swap, and as far as I know it's a direct swap. The only screwing around that you should need to do is to replace the drive & driven gears in the tailshaft of the transmission to accomodate the new gear ratio since I doubt that you'd want to replace the Dana 44's gear ratio with one of the junk gear ratios that the Dana 36s had.
Old Aug 13, 2002 | 10:14 PM
olephart's Avatar
Most people change the pumpkin and the cover. Not hard, just takes some time.
The original driveshaft will be a little long and should be shortened, but some people can get it on. The brace will need the bolt holes relocated too.
If you can get the driveshaft and brace from the 44, you have it made.
Old Aug 14, 2002 | 07:07 AM
Jim85IROC's Avatar
Oh yeah, I forgot that the 88+ had the different wheel offset.
sailtexas186548
Jan 19, 2016 12:21 PM
Americanmouse
Sep 7, 2015 12:10 PM
Chevy3shitty
Sep 1, 2015 09:22 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
MENINBLK
Aug 5, 2015 11:58 PM
