2nd to 3rd shift
Old Aug 19, 2002 | 08:19 AM
turbotater's Avatar
2nd to 3rd shift
i put a corvette servo and .500 boost valve in my trans and it made a huge difference in shifting on motor but on n20 it still shifts from second to third slower than i like . looking at the graph on datamaster 1rst to 2nd is a sharp drop off but 2nd to 3rd is slightly tapered as the rpms drop . what parts control that shift ?
thanxs mike
Old Aug 19, 2002 | 07:56 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Line pressure and valve body. Depending on torque the trans will cushion the 2-3 shift to eliminate breakage at the peak of the torque curve. The only correct way to do the job is to recalibrate the valve body for the desired result. By installing a larger servo piston you unbalance the pressures. The governor spool valve moves at a certain rate while the servo piston is generating more pressure, hence an unbalanced situation. The only way to correct this is modifing the valve body and or seperator plate. This is where you need the advise of LEO, or another transmission technician. 92 boxes are pretty good, as they incorporate all the latest mods GM Powertrain offered.
Old Aug 20, 2002 | 06:56 AM
Pro Built Automatics's Avatar
TheCorvette servo & the .500 main boost valve will help, but if you are going to leave 3rd gear as is (additional 3-4 clutches, etc.) I would add the Trans-Go Performance Shift kit or call me as to what modifications need to be done to resovle this (possibly). This kit or my modifications increase oil to the 3-4 clutches by about 250-300%, this should help out for awhile. Let me know?
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Chad Speier
Sep 24, 2015 12:32 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
