Bump under console
Old Aug 21, 2002 | 03:24 PM
HurtHorseZ28's Avatar
Bump under console
Every time I jump on the gas in my Camaro, I get a bumping sound from under the console. More like a single thud. Most likely, I am thinking it is the transmission mount. Anything else it could be? It only does it when I jump on it. I haven't took a look yet, but where exactly is the mount and where is the best place to buy one at a good price? Thanks!
Old Aug 21, 2002 | 03:29 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
you got it, tranny mount.
get an energy suspension one, instead of a factory replacement most say it will last alot longer.
my v6 broke 3 of the factory type ones, but it had bad motor mounts too, i only broke one so far with my 305 but it got new motor mounts when it got put in. i think there is a connection there
Old Aug 21, 2002 | 04:36 PM
That's what I thought. What's the part number for the ES mount? Is it the same for the V6 trans as it is for a V8?
Old Aug 21, 2002 | 04:49 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Hurthorse,
Yeah they are all the same. The ES p/n is 3-1108. I know you can get different colors i.e. 3-1108B - Blue, 3-1108y - Yellow. I think you have four to choose from. I got black which was 3-1108G. Hope this helps.
You may want to get a poly T/A mount too while your at it. They are only around $15.
Ed1LE
Sep 30, 2018 09:14 AM
Veaceonee
Sep 29, 2016 08:15 PM
Lbibb
May 5, 2016 12:00 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
ndndndnd
Sep 28, 2015 08:00 AM
