"Rumbling" under light/no load at speed
Old Aug 23, 2002 | 10:49 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I have a 90 Formula with the 700R4. I have noticed that during cruising at 60 mph with little to no load(downhill) that the tranny feels like it is rumbling. When throttle is applied or under a load (uphill) it goes away. The tranny shifts fine and shows no other symptoms. I also have a Spohn torque arm with the spherical rod end at the crossmember. Could it be coming from the rear and being transmitted through the crossmember? This problem is not a constant thing either. Somedays it occurs and some days it doesn't. Anyone have any ideas?
Attached Thumbnails "Rumbling" under light/no load at speed-mine.jpg
Old Aug 23, 2002 | 10:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is usually caused by wear in some bearing having to do with the drive shaft. Either a U-joint, or the pinion bearings (could be the nut is loose), or the extension housing bushing in the trans.
Old Aug 24, 2002 | 10:16 PM
Mongoose's Avatar
Car: 90 Formula
Any way to tell which end it's coming from? I figure the pinion will have to come out to replace the bearing there but how difficult is the extension housing bushing to replace?
69GTOby
Apr 18, 2016 02:34 PM
tyeo098
Nov 30, 2015 06:27 PM
adelane
Sep 9, 2015 08:51 PM
Eric-86sc
Sep 7, 2015 02:10 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
