Transmission Fluid Leaking
Old Aug 28, 2002 | 12:47 PM
Jeff Morgan's Avatar
Just replaced my Transmission mount a couple of weeks ago. Now, I've got major leakage. What could be causing this. It never did it before I replaced the Transmission mount. Any thoughts?
Jeff Morgan
82 Pontiac Firebird S/E
Original everything...
Old Aug 29, 2002 | 07:04 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Front seal, real seal, tailshaft, or fill holes can leak if they are worn.
Old Aug 29, 2002 | 08:22 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Transmission Fluid Leaking
Jeff Morgan
Can you tell where the leak is originating?
How did you support the trans while you swapped out the mount?
Old Aug 29, 2002 | 08:28 AM
TRANSMISSION FLUID LEAKAGE
Paul,
I not quite sure. It looks like it may be coming from that Bell Housing cover. In regards to how the transmission was supported while changing the mount. Not sure, because I didn't actually do it myself. I'm taking it back to the shop that actually did the work for me tomorrow. Bottomline, it was leaking anything until after they replaced the Center mount.
Jeff Morgan
Old Aug 29, 2002 | 09:32 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Jeff, yeah....best to just take it back to who ever did the mount replacement. I'm wondering if they just overfilled the transmission?
LittleFranks
Sep 17, 2015 12:22 PM
RED85TPI
Brakes
Aug 31, 2015 10:29 AM
someone972
Aug 30, 2015 12:52 AM
spaigo
Aug 21, 2015 07:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
