trans cooler
Old Aug 29, 2002 | 07:57 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
trans cooler
can i simply buy a trans cooler and use that in place of trans cool lines?
thanx for your help
Old Aug 29, 2002 | 08:09 PM
ede's Avatar
ede
i'm confused, your trans lines already go to a cooler and if you bought one it wouldn't just plug into your trans, you'd still need lines to get from the trans to the cooler.
Old Aug 29, 2002 | 09:00 PM
heh, i told you i dont know jack about automatics
Old Aug 29, 2002 | 09:10 PM
ede's Avatar
ede
damn i guess so. the 2 lines run to the radiator, that's the factory trans cooler, inside the radiator.
Old Aug 29, 2002 | 09:37 PM
ohhhhhhh ok
so if i bought one i would just be relocating it?
with buying new lines........i cut the old ones off because i thought i was putting a T5 in................when i buy new ones, i guess i have to bend them and flare the ends huh?
Old Aug 30, 2002 | 12:04 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Originally posted by 1991tealRSt-topGuy
ohhhhhhh ok
No, you should run the new cooler in series with the radiator cooler.
Here's how. Leave the radiator as is but tap into the tranny return line from the rad and send the fluid to the extra cooler, which you mount in front of the rad (and AC unit, if that's there too). Then send the aftermarket return line to the tranny return line and voila! You've REALLY cooled down that hot tranny fluid! This will at least double the life of an automatic tranny, no kidding.
And all for a miserable $30 or so.
deracer
Apr 11, 2016 12:04 AM
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
