383 stroker to t-56 question for a pro
Old Aug 29, 2002 | 11:14 PM
downwithET's Avatar
i have a 85 TA w/383 stroker which uses a bolt on weight to balance it, it bolts behind the flywheel, i just got done installing my t-56 and when the pedal is floored it vibrates and makes a low pitched squeaking, but when i let up a 1/2" it goes away compeletly, it ONLY does it in that last 1/2", could it be the weight behind the flyewheel screwing up the distance? hmmmmmmmm
Old Aug 30, 2002 | 01:51 PM
downwithET's Avatar
ahhh figured it out.
Old Aug 30, 2002 | 03:32 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
what was the problem?
Old Aug 31, 2002 | 02:21 AM
downwithET's Avatar
needed to make a pedal stop, mine had 1/2" too much travel
Old Aug 31, 2002 | 02:27 AM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
that is a common problem BTW. I thought I would fix it with 4th gen pedals with my McLeod clutch and PP. But I had to make a stop and another guy had to make a stop as well.
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
redmaroz
Aug 16, 2015 11:40 PM
