The OTHER driveshaft
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I've got a TH350 trans and I'm using the stock driveshaft from the original V6/auto application in my 83 Firebird. I understand that this driveshaft is a different length than all the newer ones since GM went to overdrive transmissions. My question: is there a factory aluminum driveshaft for my application, or would I have to have one custom made?
Yeah, I was afraid that was the answer. I know custom alum. driveshafts are pricey- is it worth it for the minimal gains?
Anyone take their car to the strip before and after installing an aluminum driveshaft to see the difference in e.t.?
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
i did see a difference
the car feels lighter when you get on it
it revs up easier but i got my tpis 3.5" aluminum ds used for 200 and thats the only reason why i got it
your could get a custom one for like 350 i think it might be worth it for you
i tell you at high speeds i have absolotly no vibration now with the aluminum and iff you ahve higher then 3.23 gears i recomend an aluminum ds
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
