Speedometer Gear
Old Sep 7, 2002 | 07:11 PM
JoshZ28's Avatar
Speedometer Gear
The guy I baught my car from said the speedometer gear broke, and he gave me a new gear, which i have. He said it goes in the side of the transmission, but I have no idea where to look, could you guys give me an idea of where to look, and do you think it could be swapped without jacking up the car, It's stock height.
Old Sep 8, 2002 | 11:53 AM
Jay 727's Avatar
Have to jack it up. It's on the drivers side of the transmission towards the back. The retainer is held on with one bolt and there will either be a cable or a wire plug in the center of it.
Don't get it mixed up with the governor cover.
Remove the bolt and retainer. wiggle the speedometer gear housing out, then just pull the gear off and replace it. This is assuming it is either a mechanical speedo or electronic with a gear type sender. Not the type with a reluctor and tone ring.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
TrevinE
Sep 14, 2015 03:20 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
