Would this be the cause of Megashifter hard shifting? (i did a search)
Old Sep 8, 2002 | 10:41 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I installed the Megashifter over the weekend. Everything went smoothly except it is hard to get out of park and is a little harder than my brothers Megashifter in his 81 camaro to shift. Someone in previous threads mentioned that the cable can bind on the hole in the floor even if the grommet is in place. I routed the cable perfectly as the directions said to.
It does touch the outside edge of the hole in the floor. I tried moving it but no matter what it still rubs up against the grommet tightly. I was thinking of widening the hole just a bit with the Dremel so it won't rub at all. (Someone on here did this). Do you think this might be the cause?
Suggestions welcome.
Prodigious
Nov 7, 2020 09:23 AM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
someone972
Aug 30, 2015 12:52 AM
suzuki949
Aug 28, 2015 08:07 AM
