Limited Slip Additive
Old Sep 8, 2002 | 11:14 PM
88 IROC BOB's Avatar
Someone on this board had recently said not to add any to a 9 bolt posi rearend. I don't think that is right.
I have a 9 bolt with 3.27 gears and will be changing fluid this week. Should it be used?
Bob
Old Sep 9, 2002 | 04:57 AM
Pro Built Automatics's Avatar
Use the GM (posi) additive when you change the rear end fluid. Do not use "Sta-Lube" for rear differential oil under any circumstances.
Old Sep 9, 2002 | 05:07 AM
ede's Avatar
ede
if you have a clutch type posi you need te additive, if you have a cone type, or mechanical posi you don't need it. the additive is for the clutches.
Old Sep 9, 2002 | 10:27 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I always use the GM additive in every 9 bolt I work on.
Miles
Diff Solutions
www.9bolt.com
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
