Can I build a TH700R4 to absorb 497 ft lbs of torque@4,400 RPM?
Old Sep 10, 2002 | 08:53 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I am preparing to install a 406" SBC in my ,82Z28 project car.
I want to use the TH700R4 transmission. Can "I" build one to absorb 497 ft lbs of torque at 4,400 RPM w/3000 stall converter on the street? No drag racing!
I also plan to test the car at VIR for kicks. This is training for road racing.
Thanx,ANDYZ28
Old Sep 10, 2002 | 08:58 PM
4L60bliss's Avatar
Probably so. They make hardened input shafts, super strong Reaction sun shells that utilize a thrust bearing instead of a washer, 5 pinion input planetaries and a 5 pinion reaction planetary. Most of those parts have been rated up to 800 ft/lbs of torque. I have dealt first hand w/ all of that stuff, and I really like it, but its pricey.
Old Sep 11, 2002 | 05:43 AM
Pro Built Automatics's Avatar
It depends on which 3,000 rpm stall torque converter you are going to use? What is the diameter?, does it have lockup?, etc. I have not seen 4 pinion planets ever being a problem, even in my high 10 & low 11 second vehicles. I am using the late washer type sunshell from GM without problems going on 2 years. I am sure that the later GM HD parts are good, but as of now I am not having any problems, so the extra money that this would cost, I would have to charge the customer, I cannot justify it as of right now.
Old Sep 11, 2002 | 06:22 AM
ANDYZ28's Avatar
Car: 1982 Z-28
I am planning to build a 1990 transmission, and use the B&M "HloeShot 3000" converter. But no drag racing.
I will be running a 3.42 rear.
Thanx,ANDYZ28
Old Sep 12, 2002 | 05:53 AM
All my past experience with B&M..... Save your money & get a "quality" torque converter, A.C.T., Vigilante, Continental, etc. Do not cut corners on the torque converter. If you plan on road racing this unit?, then the above TC's would work well. If I can be of help?, call me at 800 7763288 M-S 10-6 PST.
Old Sep 12, 2002 | 06:08 AM
ANDYZ28's Avatar
Car: 1982 Z-28
OK, Thank you very much. I will be calling you.
Thanx,ANDYZ28
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Cleotiz
Jan 6, 2018 08:56 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
gwade12
Aug 8, 2015 08:17 AM
