T-10 stronger then the t-5??
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys i have a 350 pushin around 350 horse in my bird witha 5-speed and i was wonderin if the 4 speed T-10 is strongder then the T-5. i don't mind have a 4 gears at all i just wunt sumtin i can beat on when i wunt and not have to worry about gettin home. also would it be a direct swap? or woudl i have to change the drive shaft,bellhouseing,etc...
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
Yea the reason Richmond says that is because it's true. A T-10 will handle Big Blocks like nothing, a friend of mine had on with 1138 h.p. going through it in his drag car running 9's (1968 Camaro). No Problems, but he sold it after about 10 runs (enough $ you know anything is for sale)
Definatly bulletproof T-10.
Later, Garrett
Later, Garrett
Car: 89 Formula
Engine: Carbed 5.7
wut about them saginaw or wutever t-10s in 82 f-bodys?? are these still really strong units?? also why would i have to mess with the clutch?
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
The T10's from the '82 year is plenty strong for whatever you may throw at it..I can attest to this after beating the s**t out of mine for 6 years now.AVOID the saginaws from the same year..those things are below T5 strength.The difference in the clutch is a T10 as in my z uses mechanical clutch linkage whereas the newer f bodies(84 and up) used hydraulic clutche linkages.It will be an involved swap if you are serious about it.
luvofjah
Sep 26, 2015 08:28 PM
