Bad tc?
Old Sep 12, 2002 | 10:17 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Bad tc?
My torque converter (or something nearby like the front pump or something) is making lots of noise at idle. Its like a hollow metallic clunking noise that happens while the engine is idleing. It seems to be occuring at the same speed as the engine rpms and it sounds like its coming from the tc. When i put the car in gear, the noise goes away and its quiet again. What is this? Oh btw, this happened while i was racing a mustang so it happend while the driveline was under load. i heard it when i got back to my house.
Old Sep 13, 2002 | 12:32 PM
Car: 88 Camaro SC
Engine: SFI'd 350
anyone??? Ill see if i can post a sound clip of it tonight..
Old Sep 13, 2002 | 03:53 PM
Car: 88 Camaro SC
Engine: SFI'd 350
duhhh The crappy threadlock i used didnt hold and all the bolts overhauled. They where all hand tight. Guess ill go get some quality threadlock and fix this crap.
Old May 21, 2004 | 08:52 AM
EdO87V's Avatar
Car: 85 Trans Am
Transmission: automatic
this happened to me too...
I took off the tc cover a couple of weeks ago but nothing looked loose. Now the noise is very bad. What did you do to fix your problem? I have the exact same symptoms you did.
Old May 21, 2004 | 03:41 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
His flexplate bolts came loose. Theres cover on the trans that can be removed to see the flexplate to converter bolts. Theres only 3 of them so you may have to crank the engine over a little to see them.
Another thing that can cause a similar noise and symptoms is a cracked weld on the tc bolt holes.
Old May 21, 2004 | 04:02 PM
Car: 88 Camaro SC
Engine: SFI'd 350
If i can remember the bolts looked fine but all where hand tight upon inspection. I had way overreved my motor racing an equally slow late model GT and the rest of the way home it made a *** awful racket when I stuck it in neutral. Take the cover off and inspect everything. Also, if its safe to do so, run the engine and try to pinpoint the noise.
Old May 21, 2004 | 09:23 PM
IROC_385Z's Avatar
Car: 88 Camaro IROC-Z
Engine: SBC 385
Transmission: 700 w/ manual valvebody & 2400 TCI
Axle/Gears: 9-bolt B&W w/ 3.70s
Rod knock
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
