gear swap and speedo ?'s
Old Sep 18, 2002 | 06:59 AM
Screamer27's Avatar
Car: 1986 Monte SS / 1988 Iroc-Z
Engine: LS3 / L98
Transmission: 4l80E / T56
Axle/Gears: 3.73 / 3.45
My friend here has a 91 RS 305 auto. Well I was lucky enough to pick up a set of 3.42 gears with the locking rear from a 96 Camaro. I can install the gears, thats not a big problem, my problem is, how do I fix the speedometer, because won't it be off by alot because of going from 2.73 to a 3.42 rear end. How do you fix it?
Thanks,
Old Sep 18, 2002 | 07:14 AM
ede's Avatar
ede
you can set up a ring and pinion but not a speedo, damn. change the driven gear on the speedo
Old Sep 18, 2002 | 11:06 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
You need a 45 tooth driven gear and a sleeve to match it. Look up my posts on this forum for all the info because I just did the same thing a month ago.
Old Sep 19, 2002 | 08:34 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Thats cold.
Old Sep 19, 2002 | 01:43 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It really depends on tire size. What size are the tires that are on the car now? Some people can get away with just changing the drive gear or driven gear. You may or may not need both. www.700r4.com/ has a calculator thats easy to use and if you do a quick search on this board you can find all the GM part numbers under one of my old threads about 8 months back.
Old Sep 19, 2002 | 07:50 PM
Screamer27's Avatar
Engine: LS3 / L98
The car has 245/50/16's on it, I went to that site,(thank you by the way) and i used their calculator, It came up saying to use a 15tooth drive gear and a 40 tooth driven gear.
Now my next question, where do you put these gears at? and how bad are they to install. I have done a few rear ends, that Is how I know what to do. But I never cared about the speedo being right Since its not my car, he cares. I was hoping since it is a 91 that it was something that was just programmed or you had to burn a chip for. O well.
Old Sep 20, 2002 | 09:38 AM
Pukka's Avatar
Repalcing the speedo gears is easy. The driven gear is connected directly to the VSS sensor or speedo cable on your transmission. Just unbolt and it pops right off.
On an auto tranny, unbolt and remove the tranny tailshaft and you will see the drive gear. I think there is still a tech article that shows this. Just be careful not to snap the retaining ring that keeps the drive gear in place.
Your wheel/tire combo is stock for that year (z28 option). Just go to a GM parts desk and tell them you want the 3.42 drive/driven gear set for a 91 Camaro. If the rep gets confused, tell him/her to cross reference it off of the V-6 model and you should be able to get both gears for under $25.
Electronic speedo cals didn't appear until the 4th gens were produced. Hope this helps.
Jorlain
Aug 24, 2022 05:11 PM
InfinityShade
Aug 22, 2015 08:00 PM
mizz0313
Aug 12, 2015 06:45 AM
beachrodder
Aug 7, 2015 04:27 PM
