what's the torque for the press. plate?
Old Sep 24, 2002 | 02:49 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
hello guys.
please, how much is the presser plate to be torqued to the flywheel?, (the one squeezing the disc?) we're talking about, the T-5 tranny, wich is goingon a 5.7?
thanks to all.
Fernando.
Old Sep 25, 2002 | 04:55 AM
ede's Avatar
ede
i use a 3/8 impact wrench and tighten the bolts till it stalls, i use red loctite too
Old Sep 25, 2002 | 06:37 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
IIRC the spec is around 35 ft-lbs
They're 3/8" std thread; they'll need about the same torque as any other 3/8" std thread fasteners
Old Sep 25, 2002 | 11:09 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
my haynes book says 16ft lbs for the pressure plate, and i believe it was 60 for the flywheel itself
edit use rb's suggestion of 35ft lbs, i was thinking of another vehicle that i have
Old Sep 25, 2002 | 12:13 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
thanks to all guys.
i've found a book where it calls also for 35 foot/pound, it makes sense, and i did use green locktite instead, i believe red will be a little too much.
anyway with the proper torque it shouldnt come lose.
thanks again to all.
Fernando.
Old Sep 25, 2002 | 06:27 PM
ede's Avatar
ede
mig29 you're confused on your loctite, green is permanate, red is temporary.
Old Sep 26, 2002 | 05:33 AM
Pro Built Automatics's Avatar
I am not sure about the green, but the red is "stud & bearing mount" and it's permanent.
Old Sep 26, 2002 | 07:35 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
DOHHHH!!!!!
Old Sep 26, 2002 | 06:10 PM
ede's Avatar
ede
either i have some low grade red loctite or your defination of permanate is a lot differant than mine. i've used red since my kart days and it isn't hard to take apart at all .aluminum, stell, brass, whatever it all unscrews about as easy as not using anything. i never use blue, not worth the trouble. since friday is trash day around here and i was in the garage i looked at mine. red 271 does say stud and bearing mount the 635 green says retaining compound (not thread locker) maximum strength. on the back is says best for clyindrical parts with a clearance of .010 (i think, it sucks not being able to see to read when you get old) or less. from reading both bottles green is by far the more permanate of the two and from all the industrial setting i've been in green was used and considered permanate while red or blue could be taken apart.
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
dbrochard
Sep 25, 2015 04:56 PM
