non thirdgen : which trans for BB502 4X4?
Old Sep 24, 2002 | 05:39 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
sorry about the non thirdgen but at least its a gm...
I am planning on putting the 502HP - 567ft-lb crate gm motor in my 81 chevy k-10 4x4 and I need to know what kind of trans I should look for for durability here.
could I get away with a th 350 or would it just blow up?
the truck has 31" tires and stock axle ratios which I have yet to determine what they are.
I will only be doing the occasional cruising and towing and the like with this truck -- no off roading or mudding and surely no dragstrip time!!!
THanks
James
Old Sep 24, 2002 | 09:27 PM
gearhead86's Avatar
You can't go wrong with the tried and true TH 400. With a little prep work it should definitely hold out!
Old Sep 24, 2002 | 09:58 PM
Dr. Pepper's Avatar
Well I would consider your real options to be a 4L80E or TH-400. With a big pocket book you could get a 700R4 or TH-350 to work reliably but this is what the TH-400 design was born for. A nicely rebuilt TH-400 or 4L80E would hold up fine. Considering the extra costs of the computer system the 4L80E would probably be second highest in cost next to the 700R4. I have an 86 with a well worked over 454 and I am running a TH-400 in it with no problems. The main transmission upgrades are the HD sprag (already had it), a kit that included name brand HD clutches, and a shift kit. The TH-400 is the most practical option since it was even available in that truck. Not counting the rebuild it cost me about $300 for a good TH-400 and a matching transfer case. Now transfer cases are a whole different headache but not an area I an overly experienced with. I simply don't push the truck hard in 4 wheel drive. I imagine that if you want to beat on it in 4 wheel drive you will need an aftermarket transfer case.
Old Sep 25, 2002 | 04:18 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
thanks guys..
TheJoeY88
Dec 31, 2016 07:30 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
ezobens
Aug 19, 2015 10:29 PM
Exxon Limited
Aug 9, 2015 08:13 PM
3rdgenparts
Aug 6, 2015 09:03 AM
