t5 slow leak
Old Sep 25, 2002 | 10:45 AM
Steve89GTA's Avatar
t5 slow leak
My t5 has developed a slow leak.
I had the case alum welded about a year ago around the lower drain plug (which hair-line cracked as I was tightening it last year after a fluid change).
The fluid looks like it's coming from everwhere though.
Is there something I can add into it to help with the leak situation until I get it out?
It's starting to whine in mid 4th and 5th gear a little as well. I think my endplay may need to be adjusted.
damn...
Old Sep 25, 2002 | 11:24 AM
lifesun's Avatar
If your T5 is a Non World Class, I think that you are out of luck for that leak. Your case has stretched enough around the front bearing that you have developed a leak. I have the same issue, NWC T5's don't have a seal around that bearing. It is only a matter of time before it stretches too far and dies. The noise is also an indication that you have torqued the case.
Old Sep 25, 2002 | 11:41 AM
Steve89GTA's Avatar
No, I have a world class t5. All the bearings and synchros were changed 5000miles ago. I think the rear section of it (where the shims are installed) has to be adjusted.
RS Reaper
Oct 17, 2018 07:52 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
