Can I get a shorter tranny dipstick and tube?
Old Sep 28, 2002 | 01:12 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
After I installed the new converter, I forgot to put the dipstick tube back in. I tried to get it in as best as I could with the tranny installed but it is still smashed against the firewall and may be giving me false readings. Is there a shortened dipstick and tube where it needs to be checked from under the car?
Old Oct 4, 2002 | 10:30 PM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
Re: Can I get a shorter tranny dipstick and tube?
[QUOTE]Originally posted by PLANT PROTECTION
[B]After I installed the new converter, I forgot to put the dipstick tube back in. I tried to get it in as best as I could with the tranny installed but it is still smashed against the firewall and may be giving me false readings. Is there a shortened dipstick and tube where it needs to be checked from under the car?
I use a shorty dipstick on my powerglides. Check with TCI or B&M.
Maybe the dipstick will also fit the 700R4.
Old Oct 4, 2002 | 10:55 PM
I see Jegs sell a flexable dipstick tube by Lokar which will work but $60, ouch. Where did you get your shorty tube?
Old Oct 7, 2002 | 08:26 AM
cdogc350's Avatar
cut the tube the length as needed (eg.=3inch.) and cut the dipstick the same length (3 inch.) and measure up the markings from the cut peice to the new dipstick end.......
no green
Jan 9, 2016 09:22 PM
NZKnight
Oct 15, 2015 02:47 PM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
