rear end ?????'s
Old Sep 30, 2002 | 06:31 PM
StylnCamaro's Avatar
rear end ?????'s
I just got my trans installed and the guy did an excellent job but my vss sensor clip came loose so he needs to do that but no biggy anyways, while it was on the lift I seen I have a 9 Bolt Borg Warner rear and the guy said it was a posi rear. Now did camaro's come with 9bolts b/c I thought they were 10 bolt and two my rpo is G80 which means
G80 : AXLE POSITRACTION, LIMITED SLIP....So is this posi or limited slip differential where only one wheel spins b/c when I light them up I only have one track behind
Old Sep 30, 2002 | 06:37 PM
ede's Avatar
ede
9 bolts, 10 bolts and dana 44s all came in third gen f bodys. only differance in posi and limited slip is the spelling
Old Oct 1, 2002 | 02:02 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
99+% of 9 bolts were posi/limited slip. Sounds like your posi unit is worn out. They are available at www.9bolt.com
Miles
Diff Solutions
Old Oct 1, 2002 | 07:28 PM
I noticed today that are two burn out marks where I last lit them up and on the rack If I hold one and have the mechanic try to spin the other it can't be done, so maybe it isn't worn..
But out of the 9 bolt 10 bolt and dana44 which is better or how would they be ranked 1 the best 3 the worst
Old Oct 1, 2002 | 07:30 PM
and would this be the 7.75 I have or the 7.625, which one?
Old Oct 1, 2002 | 08:33 PM
4L60bliss's Avatar
9-bolt: 7.75"
10-bolt: 7.62"
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
