Why does car lurch/heave when put into gear??
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Hey...I've noticed this ever since I had the car but seems like it may be getting more pronounced lately...maybe I'm just paying more attention to it.
When shifting from PARK into RVS or DRV...I feel a big lurch/heave in the direction of the gear.
What is causing this?
Car: 1990 Iroc Z convertible
Re: Why does car lurch/heave when put into gear??
I also have this same problem with my 1991 z28 when i put it into gear .
Could it be the rear brakes not working for some reason......?
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I have had this problem since I got my car in 2006 (it's an 86).. I got my tranny rebuilt, rear end rebuilt, driveshaft and joints new, rear brakes new...
To describe it, it sorta bangs into drive or reverse and lurches forward or backward, right? I have heard that this is from the lack of an improvement they made in the 1987 700R4's called the accumulator spring (correct me if I'm wrong) that cushions something when it gets put into gear.
Short story: I got pissed when I rebuilt the tranny and the builder told me that there was no difference from an 86 700r4 and a 87 for example.. After it was built he did say there was that improvement and that he didn't think I would care about that because it has nothing to do with the 'performance' of it. The tranny shifts so well now so I didn't bother to change it again to fix that lurching problem, but either way you can't add it to an older 700R4, you have to have a newer one.. But the weird thing is that you have a 91 Z28 so I would think it wouldn't do that like my older 86? Odd..
idle speed to high...do not trust the tacho! Get a timing gun w/ rpm indicator and go from there
yes
Hmm. My idle sits comfortably around 750 or so, sometimes a bit lower at 650, after all my tuning I got it this low and happy.. But it still does it when I start the car, but oddly, it doesn't do it when the car is cold or after a minute of starting, seems odd though, because it does it when it's warmed up.
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
its the power ready and rearing to pounce
The ujoints should be good.. What are the signs of them going south? Looseness?
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
My 87 LB9/700R4 does this as well, but my LHO/700R4 92 RS does not. I have got use to it, but you do notice it for sure.
Car: "Nina" 1988 Trans Am GTA
Engine: TPI 305 V8
How about the tranny mounts? I remember my '86 clunked and lurched when they were shot.
I had rubber, it was decent, upgraded to ES poly mounts, (had some drivetrain vibration on highway), changed to prothane mounts and there's no vibration but still this lurching problem.
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
Drivetrain slop, be it in the splines, u-joints, or lash in the r&p can cause the sensation, so can brakes that don't hold as well as they should. I avoid autos, but if all those things are good, process of elim says its in the trans.
When a u-joint is on the way out the cross will have play in the cups, rotational, side to side, front to back, up and down, whatever, if it has perceptable play its not long for this world. Don't confuse play in the pinion or trans out for play in the u-joint. Looseness in my mind means the joint moves within the yoke, in which case both should be changed.
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
Throttle cable adjustment. Before I adjusted mine it had no problem... after I adjusted it now its lurching hard when I shift from park to drive. Try doing a real adjustment. Like I'm doing tomorrow.
Posted from Thirdgen.org App for Android
I'll check ujoints out.
For the throttle cable adjustment, what is the simplest way to do that?
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I'd also say it's time to take the throttle body and IAC out and clean them with carb cleaner. Mine was amazingly dirty inside for how low of mileage it was. (I did this about 4 years ago). Once you've reassembled it, follow the instructions for setting the IAC, min idle, TPS settings here:
https://www.thirdgen.org/tpimod2
If the min idle is too high, it will bang into gear. If it's set right, it won't.
The other issue is a broken rubber transmission mount as mentioned by another poster.
I will try adjusting the cable too, and i'll clean the throttle body as well. I think mine is leaking air slightly so I might buy a new 52mm ported one (one of those EBAY type re-inforced ones). I have a new IAC and TPS and I know the TPS is adjusted perfectly at 0.54 (or 0.52, whatever it was supposed to be at when I did it), but the IAC I'll have to look at to be sure.
For the throttle cable: When you say "release the "D" button, do I release the cable at the time same? Or have I already let go of the cable at this point? And when you say rotate the throttle to full throttle, do I just turn the throttle on the side of the throttle body and hold it at full throttle until the cable stops moving?
Sorry for the Q's, just wanna be sure so I don't burn up the tranny!
Thanks Reid,
-Marc
Thanks Reid,
-Marc
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
I had the same thing with my car it was annoying as heck. In my accumulator piston instead of the springs to soften shifts there was 3 washers and a nut to make the shifts "harder". Instead it probably played a key role in ruining the trans along with some of **** I seen done to the trans.
Car: 1989 GTA
Thanks Reid,
-Marc
Thanks Reid,
-Marc
You are correct about simply reaching over to the throttle on the side of the throttle body. Turning that to full throttle will ratchet the cable forward to the "exact" spot it needs to be in.
Many people foolishly try to manually adjust the cable in order to get a firmer shift. But it's one of those deals where it's either set 100% perfect or you'll end up burning up the transmission.
Wow.. I wish I knew exactly what went into mine.. Thanks for the info I'll be doing this over the weekend, hope it helps! Thanks Reid!
hectre13
Dec 11, 2023 08:14 AM
dhonda200
Aug 11, 2015 11:50 PM
I just keep tellin' this to people who come in the car and ask
