people with SGI-5 calibration boxes..
Old Oct 2, 2002 | 02:38 PM
breathment's Avatar
Did anyone else have a problem with wiring the +12 up to a switched voltage source? I have mine wired into one of the power window switches (bad idea by the way).. and EVERY time i start my car.. it gets all wacko and the speedo will jump up to 140 when im going like 10 MPH.. and the ONLY way to fix this.. Is to take the ground wire off, reset all the switches back to default (1-3 off 4-10 on) and reconnect the ground wire and but the switches back to the right calibration setting.. I have to do this EVERY time I turn the car off. but last night i wired the +12 into the cig lighter.. and it works fine now when i turn it off and back on... what is the cause of this?
Old Oct 2, 2002 | 11:44 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Well, sure sounds like you have it all figured out to me. Must have been a problem with that power source. FYI, I have mine tapped into the Accessory power as well.
Old Oct 3, 2002 | 02:22 AM
Z_Ghost's Avatar
breathment
The first time you give me a ride in your car I am going to push the cigarette lighter and watch the speedo go crazy.
You can find places on the fuse box that lets you plug in wires and some of them are only on when the key is on.
Old Oct 3, 2002 | 04:23 PM
breathment's Avatar
Originally posted by Z_Ghost
breathment
haha.. thats what it did when i had it hooked up to the power window switch..
im sure once i get my new center console i'll do all the wiring more nicley.. right now i have to many wires running in all directions.. and holes in my floor with nothing covering it.
Old Oct 3, 2002 | 09:42 PM
Matt87GTA's Avatar
No worries, I have used the lighter and it did not disturb the Speedo.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
MadOTC
Oct 13, 2015 04:46 PM
