Bolt-on OD?
Old Oct 8, 2002 | 12:27 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Bolt-on OD?
A friend of mine was telling me about a device which you can bolt on to a TH-400 and im sure any other GM auto tranny and that it would basically double the number of gears it would have.
He told me it was a kit and that on the shifter there was a button on the side that would engage the gear in the extension. And when you ratchet the shifter forward it disengaged the gear so that you go:
1-OD
2-OD
3-OD
So that you now have a 6-speed auto transmission with the strength of TH 400. The extension is supposed to hold up to 1100 HP.
I was wondering if anyone else knew of this or has/is using one.
Apearant;y they used it on the TH-400 that was behind the new GM 572 crate motor. Certainly quite a deadly combo.
Old Oct 8, 2002 | 06:57 AM
Recluse's Avatar
Its made by a company called GEAR VENDORS. Go to their websit and check it out. do a search. theres all kinds of info about it.
Old Oct 8, 2002 | 09:49 AM
MdFormula350's Avatar
yeah i saw something like that on the show called "Trucks" on the TNN network..
they put it on the th400 also.. cost alot also, over $1 grand
Old Oct 8, 2002 | 11:53 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
It's the gear vendor over/under drive unit. Cost ~$1800-2000.
Miles
Old Oct 9, 2002 | 02:48 PM
Car: 92' RS
Engine: LO3
Wow, its $2,300 for the 700R4
Nevermind, its a nice idea, but not $2,300 nice.
Old Oct 9, 2002 | 02:56 PM
chacane67's Avatar
Where are you guys getting these quotes for 700R-4's? You guys are getting hosed. There are three or four companies here in So. Cal. that offer a 700 or a 4L80 w/a converter built to your chassis for $1500.00.....
I have put 600HP 502's in front of these trannies just to let you know that they wont just fall apart like some products on the market. I wouldnt really advise anyone to put a Gear Vendor's unit into an F-Body though. You will find yourself to be very space limited.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
80's Al
Mar 31, 2002 07:54 AM
87kevroc
Apr 14, 2001 09:32 AM
mostafa3k
Mar 13, 2001 09:01 AM
