How to pick the right converter?
Old Oct 8, 2002 | 07:19 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
I heard you do it but cam specs. I was thinking of getting a ZZ9 cam from TPIS. What converter would be a good chopice for this cam? What are the key factors in deciding?
Old Oct 8, 2002 | 10:06 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
When you are picking out a torque converter in reference to a cam, you want to go 300 rpms higher than where the power band starts. IE, if your getting a comp cams xtreme energy cam with a power band of 1600-6000, then you want a stall speed of 1900 rpms (300 higher than the initial 1600). If it has a power band of 2000-6000, u want a torque converter with a stall of 2300. And so on, that's the main thing that you want to look at. What kind of cam are you getting, and what kind of TQ's have you been looking at?
Old Oct 8, 2002 | 10:13 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
NOne as of yet, looking at a ZZ9 cam, vortec heads, 1.6 rockers, scoggin dickey base, tpis runners-plenum, and a tpis tb. Maybe a set of hooker headers, and a mufflex exhaust. I know Precision Industries makes an awesome converter with there Vigilante, but the price is steep. Any suggestions?
Old Oct 8, 2002 | 10:14 PM
Stingraye's Avatar
Car: 1986 Trans Am
what's the power band on the zz9 cam, and what kind of trans are you runining?
Old Oct 8, 2002 | 10:28 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
TPiS Hydraulic Roller Camshafts
All TPiS hydraulic roller cams have a cast iron distributor gear. This allows you to use the stock distributor gear.
ZZ-9 Hydraulic Roller
Intake Exhaust Advertised duration 282 287
Duration at .050 212 226
Gross lift .483 .520
Lobe separation 112
http://www.hr3rdgen.org/photos/sept2...=irocet_03.jpg
Old Oct 10, 2002 | 12:06 AM
Stingraye's Avatar
Car: 1986 Trans Am
Do you know what the powerband is on that cam?? (IE 1600-6000), or a website where it's specs are listed?? And what trans do you have?? A 700, or a Th350?
Old Oct 10, 2002 | 05:41 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
i pulled that info from TPIS website.... and I've got a 700R4
Hotrodboba400
Dec 10, 2019 07:07 PM
fasteddi
Sep 10, 2015 09:32 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
