How difficult is this?
Old Oct 14, 2002 | 10:08 PM
XxPichulonxX's Avatar
i just want to cheaply make my 700r4 go to OD full throttle, how hard is it to install this part? http://www.jegs.com/cgi-bin/ncommerc...32&prmenbr=361
Old Oct 15, 2002 | 06:11 PM
at least where does it go?
Old Oct 15, 2002 | 07:20 PM
4L60bliss's Avatar
I'm sure the valve will come with instructions, but if its the one I think it is, you won't have to pull the valvebody. You'll have to remove the two bolts holding the Throttle Vave linkage assembly and remove the linkage and probably the 1-2 accumulator housing (for clearance). Once the linkage is gone, you will see that it covered a roll pin right where the TV Plunger is (springy valve that sticks out of the valvebody and has grooves cut into it). Pull that roll pin out and remove that plunger (a sleeve will come out with it). The sleeve that comes out with it is the one you are replacing. Take note where the groove on the sleeve is towards the end, because thats where the roll pin goes in to retain the sleeve, it will need lined up with the roll pin hole. Then put the linkage and accumulator (if removed) back on. This is a condensed version, so consult the instructions that come with the sleeve.
Old Oct 15, 2002 | 08:33 PM
good I was hoping I wouldn't have to remove the valve body, if i did i wouldn't bother, thanx
Falcon50
Aug 22, 2020 03:26 PM
PurelyPMD
May 5, 2016 04:57 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
roysatikas
Sep 22, 2015 08:15 PM
