stupid tranny leak
stupid tranny leak
Ok I need help from all you trans gurus sinse I have no clue when it comes to them. I have a new 700R4 with maybe 2000 miles on it. When my car is moving I have a leak, but when it is in park it doesnt leak. I started my car and ran it for 20 minutes and there was no leak. I went around the block and came back and parked it and looked under the car and there is a slow constant drip. I would say for every 100 miles I drive Im losing a quart of fluid...any ideas?...thanx....D2M4E.
P.S.
This is what I get for converting it from a 5-speed.
P.S.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Out of the front, pan, back? It might be the pump seal, might be the front seal, maybe pan gasket not sealing 100%, rear seal could have been damaged when installing driveshaft. Loose tranny line into tranny? Clogged vent-is it draining down dipstick tube?
Mine leaked like a sive when I first got it back and I thought it was the front seal from when I installed the new stall, after I pulled the 700 and installed the 350 it ended up being the pump seal that was bad.
bubbaz28
Sep 18, 2015 02:09 PM
