2 questions..stall & gears
Old Oct 16, 2002 | 02:19 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
First question is I have a stock 1991 RS with a 305tbi. What rear gear ratio is stock, because I need to swap gears and need to know what carrier it is (I think it's 2:73 or something like that).
Second question is who has the best deals on stall converters (3000 and above)?
Any links to there site?
Old Oct 17, 2002 | 10:08 PM
Pro Built Automatics's Avatar
The torque converter will do the most for the money, then cam (mild), then rear end gears. Let me know if I can be of help?
Old Oct 18, 2002 | 09:00 AM
GOFASTER's Avatar
Engine: 388 ci
You can help, can you tell me what gear carrier I have stock? 2:73's or 3:08's?
Old Oct 18, 2002 | 09:04 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
you need to check your rpo codes or for a tag on the rear. I think on the rpo codes look for the one that says "GU" I think. It will have a number beside it. This should tell you what gear you have.
Old Oct 18, 2002 | 12:20 PM
Fast3rdGen's Avatar
3.08 and 2.73 use the same carrier. the other is the 3.23 and numerically higher carrier.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
