reverse problem t-56
Old Oct 26, 2002 | 04:37 PM
PIMPINPHIL's Avatar
hi,
why cant i seem to find reverse on my t-56?it is a 93 out of a z camaro,i have a hurst shifter,from the factory,i can find every other gear,why not reverse???thanks.and i know it is all the way right,and up.
pnil
Old Oct 26, 2002 | 10:14 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
You cut the hole large enough for the shifter? maybe cant get it over far enough to the right to engage.
Old Oct 26, 2002 | 10:33 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
maybe the reverse lockout solenoid is bad. stuck in the on position.
Old Oct 26, 2002 | 11:27 PM
Dragroc's Avatar
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
Supposedly you have to wire the reverse lockout solenoid to the brake switch so it deactivates when you push the brakes. That meaning when you push the brakes, you will then be able to put the trans in reverse.
Old Oct 27, 2002 | 06:42 AM
Car: 1988 IROC-Z
then again if it's not what is mentioned above, you may have the same problem i had. the syncros on reverse went out.
Old Oct 27, 2002 | 01:26 PM
Dragroc's Avatar
How much did it cost you to have your synchros replaced?
Old Oct 27, 2002 | 02:37 PM
Car: 1988 IROC-Z
i had it rebuilt at the also at the time.... might as well. it cost me $950 w/ warranty.
Old Oct 27, 2002 | 05:36 PM
PIMPINPHIL's Avatar
i didnt know wea had to wire in the reverse lock out,how do i do that?which plug is it on our trans?and where can i get that plug,it didnt come with it,so is this my problem?the hole is big enough also,thanks.
Old Oct 27, 2002 | 06:17 PM
Arntzman's Avatar
You don't have to wire the solenoid to shift into reverse. The solenoid just makes it easier to shift into reverse. To shift into reverse push the shifter to the right, like you are going to shift into 5th. When you feel it stop moving to the right, push harder, you feel another spring and the shifter should move farther to the right. Now just push the shifter forward and you are in reverse. Energizing the solenoid just makes shifting into reverse easier. But take it from, you don't want it on all the time because when you go to shift quick from 4th to 5th, you can very easliy grind your reverse gear if the solenoid is energized.
There should be some threads in the archives about wiring up the reverse solenoid.
-Dave
Old Oct 30, 2002 | 11:18 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
if the synchros are out can't you just duble clutch
Old Oct 30, 2002 | 11:23 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
i had the hardest time tryin to find reverse when i got my used tranny, but of course i didnt have a stick on the shifter yet so i couldnt put enough torque on it to move it over there.
it is a bit hard still to get it in even with my Hurst Billet/plus shifter
Old Oct 30, 2002 | 05:38 PM
PIMPINPHIL's Avatar
update
hi guys,
update,i found it,lol,i wasnt pushing hard enough,thanks for all your reply,i was getting a little scared there for a minute,lol,thanks alot.
GTAman
Jul 3, 2024 07:29 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
