tranny identification, 3-speed muncie??
Old Nov 3, 2002 | 03:39 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guy i was at the junk yard today and i foudn a tranny and it looke dliek a muncie to me cause it had the 7-bolt side cover and all. so i took down the numbers and tried to find them onlien for hours and i have nuthin, i am thinkin maybe its an old 3-speed. cane sum1 help me out with this, here are the numbers, tailshaft-3873986, case i think- 3952645, and side cover or case, 3925647
thanks
Old Nov 3, 2002 | 05:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The numbers don't do too much for me...
How many shifter shafts does it have? If it has 2, it's a 3-speed; if it has 3, it's a 4-speed. If it's a 4-speed, and the reverse shifter shaft is in the case (not th eextension housing), it's a Saginaw. If the reverse shifter shaft is in the ext hsg, it's a Muncie or a Warner. If the case is aluminum but the cover is iron, it's a Warner.
If it's a 3-speed, odds are very high that it's a Saginaw.
Old Nov 4, 2002 | 10:57 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Like RB8 said its very hard to tell. Muncie made HD 3speeds and they are RARE! Ive got one in my 76 PU and they are very rare in trucks also. Ive heard tale of Muncie 3 speeds in 1st gens but all Ive seen are Saginaws. I'll check my ID numbers tomorrow and see if I come up with a match. I remember hurst www.mrgasket.com/ has a huge list with ID numbers in a shifter selection PDF file.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
