Wont downshift or kickdown :T
Old Nov 6, 2002 | 07:04 PM
EddieDellz's Avatar
Well it upsifts just fine but after that it wont downshift for nothing! =/ or kickdown when you floor it i have to shift down manually to get it to do anythign of the sort .. this has been ever since i bought the car it never worked right for me i was thinking ill just rebuild the tranny but if i where to go trough that trouble id just swap in a manual.. the kickdown cable looks good 2 .. anyone have any ideas of what i could try or what it could be?
-Ed
Old Nov 9, 2002 | 02:32 PM
Sostar18's Avatar
I had the same problem untill I tightened the kikdown cable. you must make sure it is tight. Even if you must put a srew in to hold it.
Old Nov 9, 2002 | 02:44 PM
Pro Built Automatics's Avatar
Find the transfixleo method (board archives) of adjusting the TV cable, this should solve it.
Old Nov 12, 2002 | 06:34 PM
EddieDellz's Avatar
Im allmost cirtin its not the kickdown cable i adjusted it and checked it .. another reason is that it dosent only not kick down it doesnt really downshift unless your allmost going to stop and even then its a maby thing.. could it be that i just need a new valve body? or some sticking valves?
Prodigious
Nov 7, 2020 09:23 AM
tyeo098
Nov 30, 2015 06:27 PM
someone972
Aug 30, 2015 12:52 AM
JakeJr
Jan 14, 2001 01:37 AM
Locry
Sep 22, 2000 01:00 PM
