T-5 Rebuild kits??
Old Nov 11, 2002 | 07:14 PM
STIFFLER's Avatar
T-5 Rebuild kits??
can anyone tell me where to get a good one..??? can you get beefed up ones for it so it can handle more power?
thanks!
Old Nov 11, 2002 | 09:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
People may tell you theirs is "better", but the bearings all have the same part #s on them...
www.gearzone.net has them, seems to be decent pricing.
Old Nov 11, 2002 | 10:49 PM
PonchoTA's Avatar
I got mine from www.hanlonmotorsports.com They are EXTREMELY knowledgable, and the video is excellent as well.
Very complete kit, and even when I found an additional part that I needed in a hurry, they expedited it out to me.
Very satisfied.
hth
Old Nov 11, 2002 | 10:54 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
www.5speeds.com, i got a kit and a manual from them and was very happy
Old Nov 12, 2002 | 01:38 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
hmmm, t5's are inherently weak...they are prone to gear spread at high shaft speeds, and the case is prone to flex under load which also spreads the gears.....the world class t5 is a bit tougher(but not really) the damn things just basically suck, i had 2 cars with them both trannies were junk. if your gonna make any kind of power, do what i did and go with the tremec 3550 or TKO. i have the TKO which is tougher but even pricier. However, as with most things you get what you pay for.
Old Nov 12, 2002 | 11:42 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I have to put in another vote for hanlon. I used their kit and video. Their kit is a few bucks more, but when I had a question I got an answer on Saturday when I called. So it was worth the few extra dollars to get the hanlon kit. The video is outstanding by the way.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tonys91rs
Oct 10, 2015 03:31 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
