Dumb ? about shifting an auto
Old Nov 17, 2002 | 12:40 AM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
ok newbie driver here and i just wanted to make sure that it's ok to shift the gears manually in an auto trans car right? i just start out all the way down in 1st and go up from there right? i just wanted to check so i don't mess the trans up! and any tips/tricks on how to do this good? thanks
Old Nov 17, 2002 | 10:29 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Its fine to manually shift your automatic transmission just dont go overboard holding shifts way past the point where your engine makes power. The best thing to do is get a governer calibration kit so you can program your transmission to automaticly shift at the points where your engine makes peak power.
Old Nov 17, 2002 | 12:48 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I wouldn't suggest shifting all the time. Try a search, I forget the reason, I believe the line pressure is raised and over time that can be bad, but every now and then should be fine.
That's what I do, when I want to go a little faster than normal.
Old Nov 17, 2002 | 04:24 PM
Pro Built Automatics's Avatar
What year do you have?
Old Nov 17, 2002 | 04:28 PM
Car: '86 IROC
i have an 85 with overdrive. it's not running yet but i want to practice on my sis's 98 cavalier. her car goes 1-2-3-D so i just thought it would be fun and don't want to wreck anything :lala:
junior419
Apr 7, 2025 11:35 AM
F-body driver
Mar 6, 2023 11:44 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
Rally Smith
Sep 14, 2015 06:59 PM
