rear end modifacation
Old Nov 18, 2002 | 05:23 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
ok, so lets say i have this rear end.
now to my knowledge, i am going to have to make the axle tubes wider to fit into my camaro.
now how do i go about getting the old tubes out of the differential housing to be able to put the new ones in?
Old Nov 18, 2002 | 08:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends on what diff you're talking about and how the old tubes were installed. Most tubes have spot welds holding them in. Drill, grind, air arc, out the spot welds then press the old tube out of the housing. If the tube is welded all the way around the housing then all that weld also needs to be removed.
Old Nov 19, 2002 | 12:40 AM
Car: 1985 Z-28
Engine: a big one
okay, thanks
i haven't seen the rearend yet. bought it on ebay for 25 bucks
it is a dana 44. so i take it the tubes come out somewhat easy?
later
andrew
Old Nov 19, 2002 | 02:21 AM
cy Z28's Avatar
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
WHY?
For all the modification you're going to have to do why did you buy that for your car? Save the cash and build up a ten bolt, or buy a 12 bolt from moser. The Torque arm won't mount up, all the brackets will have to be cut off and re attached. And to topit all off, you want to WIDEN the rear??
If you just have to have the 44, get new rear wheels w/ a diff offset. That'll make up for your width, to a point.
Old Nov 19, 2002 | 02:23 AM
cy Z28's Avatar
oh, and it's a pain in the *** to do what you're talking about.
If you bought it because it's cheap.. that makes no good sense.
Just because you COULD have sex w/ a nasty chick doesn't mean you SHOULD, know what i mean?
Old Nov 19, 2002 | 02:23 PM
Car: 1985 Z-28
Engine: a big one
well there is another reason i am doing this.
i am going to an engineering school, and quite possibly will be working for one of the big three when i get out of college.
not only am i building this car for fun, but i also want to be able to take it to my interview and have them look at it to see what i have done. and when they start choosing who they hire, i can be that much higher on the list.
i also don't have the cash to buy a 12 bolt from moser. but i do have money to buy stock steel and cut it and weld it.
Old Nov 19, 2002 | 02:36 PM
ede's Avatar
ede
i've moved a lot of center sections in trucks for mud racing ,about the same work as to remove the tube. i used arc air to blow out the welds then die grinder to finish it off. jack the center to make it rotate, or in your case pull the tubes out.
Old Nov 19, 2002 | 04:34 PM
MdFormula350's Avatar
that is a good reason, good luck with that!
Old Nov 20, 2002 | 04:08 AM
cy Z28's Avatar
oh, well. There ya go then.
Old Nov 20, 2002 | 12:40 PM
Car: 1985 Z-28
Engine: a big one
sorry if i sounded harsh or something, most of the time when i get a reply to my questions, most of the time it is "why would you want to do this, when you can just buy it" or something like that.
so the axle tubes pretty much slip out easily once the welds are gone?
sweet
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
