700-R4 question
Old Nov 23, 2002 | 07:24 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
700-R4 question
gotta crawl under one today without a lift. can you get out the tv boost valve out without dropping the valve body. looks like there's room but I dont want to drop the pan if I have to remove the VB.
Old Nov 23, 2002 | 08:32 AM
4L60bliss's Avatar
Are you refering to the Throttle Valve, or the Main Boost Valve? The Boost valve you can access w/ removing the valvebody as it is in the pump. The Throttle valve you cannot because the back roll pin must be removed from the case side of the valvebody.
Old Nov 24, 2002 | 08:40 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Thanks, I call it the tv boost but I was referring to the tv valve. I opted not to freeze my *** off yesterday. Figured I couldn't fudge it. Thanks again, Dan
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
